| CB200 Build | |
+3manx8valvetriton pauliexjr slippery 7 posters |
slippery
Posts : 13 Join date : 2011-02-23
| Subject: CB200 Build Thu Mar 03, 2011 3:43 pm | |
| I picked up a 1976 CB200, non runner but more or less complete that I will be attempting to fettle into a presentable Cafe Racer. After a lot of build reading and image browsing I think I have the final vision but after reading Spidermans CB200 build diary and some of the comments I have decided to make sure that I get the engine right before I concentrate on anything else and as such she is now stripped to the frame with the barrels in for a rebore and the head in for a helicoil to remove the broken spark plug and sheared off easy out!! I am hoping that I can then rebuild with new pistons and reseated valves and get it soda blasted as a complete unit rather than a complete strip down. I'll then remove and plug the starter motor and get to polishing the cases and rocker cover and fit some shiny new nuts and bolts. I guess then I move onto the wheels, polish the rims and respoke (not sure where to source spokes from yet) and rebuild the forks and fit new shocks and then take on the frame, which I am really looking forward to with grinder and Mig in hand!! I'll keep the post up to date and welcome any comments or suggestions. Cheers S https://2img.net/h/i261.photobucket.com/albums/ii48/slippery27/CB200/064.jpghttps://2img.net/h/i261.photobucket.com/albums/ii48/slippery27/CB200/063.jpghttps://2img.net/h/i261.photobucket.com/albums/ii48/slippery27/CB200/003.jpg | |
| Subject: Re: CB200 Build Fri Mar 04, 2011 1:47 am | |
| That looks like fun! Good luck with the build, and piccies, piccies, piccies, they're worth a thousand words! | |
manx8valvetriton
Posts : 31 Join date : 2011-02-26 Age : 53 Location : Leicestershire
| Subject: Re: CB200 Build Fri Mar 04, 2011 11:53 am | |
| Keep us posted looks like a real good project all the best Jon | |
slippery
| Subject: CB 200 Progress report Fri Mar 25, 2011 12:21 pm | |
| Progress so far has been steady, the engine has been completely stripped, the barrels rebored and the broken plug thread helicoiled. The starter has been removed and an engineer is fabricating a suitable plug. All pretty straight forward once I managed to remove the oil filter and fabricate a tool to remove the lock nut behind the filter. I must say a big thankyou to my impact driver as I dread to think the problems that I would have got into without it. All engine parts have now been soda blasted and I am really looking forward to the results when I collect on Monday. All gaskets and O rings have been delivered by Mr Silver ready for the rebuild next week and Ebay produced a set suitably sized barrels, pins and clips for £25!! I also purchased a Haynes Manual which I must say was a complete waste of money and hasn't helped, it'll be back on ebay next week!! With the engine away I have turned my attention to a few other bits and bobs and started having a few problems. The swing arm as the bolt was and is still siezed in the frame and swing arm. So I cut it out and now while I have at last removed the swing arm from the frame I still have the bolt sections, bushes and spacers stuck. I can only think that I am going to see if I can find a press that will do the job, should be OK on the swing arm but not sure about the frame. Watch this space. Once removed I'll have to hope that I can rescue the spacers and look at replacing the bushes with brass. Next on to the forks, which strip down no problem until I tried to remove the cup that sits over the top of the botton section. These cups are not available, so I am loath to cut them off, but really need them off to replace the fork oil seals, polish the stantions and send to chrome. They are totally seized and they wont budge, think I need to fashion some sort of puller, but just such a small space to work with. Post some picture tomorrow. Carbs are stripped and cleaned and gasket sets ordered for both from Mr S along with set for the fuel filter and a set of shocks. So far so good. Cheers S | |
| Subject: Re: CB200 Build Fri Mar 25, 2011 5:35 pm | |
| Where are you Slippery? I have a set of 3-leg presses which might just remove your siezed/cut bolts rather than going to an engineering shop. If you're close enough I can possibly drop them off on my travels. Paul | |
slippery
| Subject: Re: CB200 Build Sat Mar 26, 2011 5:04 am | |
| Hi Paul, that is a really kind offer but I think that my being in Bournemouth puts us almost as far away as possible!!! | |
| Subject: Re: CB200 Build Sat Mar 26, 2011 6:58 pm | |
| Actually bud, i was in Poole three weeks ago and Bristol/Clifton the week before that. But yes, practicalities mean it's probably going to be a month at least before I'm back in your neck o' the woods.
A thought, try heating the outer with a blow torch, then use a suitable sized drift (such as a socket) slghtly smaller than the diameter of the hole, preferably over an open vise or similar, and give it a good welt with a lump hammer. | |
slippery
| Subject: Re: CB200 Build Thu Mar 31, 2011 7:39 am | |
slippery
| Subject: Re: CB200 Build Sat Feb 25, 2012 12:43 pm | |
| Subject: Re: CB200 Build Sun Feb 26, 2012 12:11 am | |
| Go on Slippery, that much polishing, you're just addicted to the smell of Autosol! Looking good bud, keep it up | |
| Subject: Re: CB200 Build Sun Feb 26, 2012 5:52 am | |
| looking sweet got a good contact for tank cleaning if needed ,can post pics of what ive had done in the past | |
rocket red
Posts : 2 Join date : 2011-10-22 Age : 48 Location : cornwall
| Subject: Re: CB200 Build Sun Feb 26, 2012 7:01 am | |
| Looking good I'm building a cb200 café as well, you've bought the same bars as me great minds and all that. | |
slippery
| Subject: Re: CB200 Build Mon Mar 05, 2012 2:30 pm | |
Posts : 96 Join date : 2011-10-26 Age : 58 Location : Feltham, England
| Subject: Re: CB200 Build Wed Mar 07, 2012 1:12 pm | |
| Some proper hard work gone it to the build, fair play, lookin real cool
slippery
| Subject: Re: CB200 Build Sun Mar 25, 2012 1:03 pm | |
| Gettting the Mig out for some bracketry Slight redesign to the rear Quite happy with the lines Tacking on the new hangers for the rearsets, complete with the first holes I have ever tapped. Dont worry these will be tigged by a professional. A bit more bling Nice rear sets | |
| Subject: Re: CB200 Build Tue Mar 27, 2012 1:24 am | |
| that is so looking good | |
slippery
| Subject: Re: CB200 Build Thu Jun 21, 2012 3:16 pm | |
| Still plodding along finished the frame at last so offer for blasting and powder and here we have gloss black and no grit or powder in the threads. more presents swing arm and engine brackets new bushes more new bushes had to paint the spacers Back end together On to the front. Tapered roller bearings me thinks front end mock up awaiting new headlight brakets And now for the lump need and few fresh engine bolts and then on to the electrics. I have a few decisions still to make. Indicators or not? Number plate location? Fonts fender or not? Gaiters or not? and of course do I try and polish the headers or wrap them, I am very undecided on wrapping. Hope you enjoy the pictures. Cheers | |
| Subject: Re: CB200 Build | |
| CB200 Build | |
