06-30-2015
Having a look at the wiring today, it didn't come with a key so I'm wiring things to the battery for now to try and get it going. My budget is roughly £0 so hopefully it doesn't need too many parts.
Think I might just wire in a toggle switch as a battery isolator instead of the ignition switch.
09-10-2015
Got a spark after about 15 minutes of fiddling with the wiring.
Cleaned out the tank then poured fuel in it only to find out there was about 100 pin size holes in it... More like a sieve than a fuel tank.
So i got an old lawnmower tank from my Grandpa and strapped that on. Had a go at starting it but no luck. Think I'll take the carb off and clean it.
09-11-2015
had a go at starting it today, took the carb apart and cleaned everything, then put it back together.
carb was flooding so I took it apart again and changed the level of the float which solved that. Wouldnt start so I put some oil in the cylinder to raise compression and managed to bump start it down our driveway. Ran for about 100 meters before it ran out of fuel. Took it back to the shed, refuelled but then after a few kicks it seized up.
So I removed the head, removed exhaust then the barrel and took the piston out. The piston was seized in the barrel. Cleaned them all up but the piston has seen better days. The bottom ring is gone and the top one is compressed to the same size as the piston. There's also a chip from the bottom of the piston so I think it's worthwhile replacing the whole lot.
09-15-2015
I put the top end back together today, got the piston assembled and put back on. Made up a new gasket for between the barrel and crankcase, really I should have bought one but the home made one from gasket material worked out very nicely. Also when I took the head off it one of the nuts was completely off and the other three were fairly loose, probably not helping the compression much... Now all done up tight.
Changed the gearbox oil too, the old oil looked very clean but better be safe.
I've marked on the 2 stroke oil tank the level of the oil in it, so I can tell if the oil pump is working after the engine has been running for a while. For now I've put 2 stroke in with the fuel, premixed, at 40:1. Test run hopefully tonight, let me know if there's anything else I should do/check!
Tried again tonight, wouldn't start so I tried putting some fuel in the cylinder and it would start and then stop. So checked the fuel line and there was a kink in the line just before the carb, sorted that and it started first time!
Took it out just down the road and some off roading, ran really well! I don't think the oil pump is working, the level is the same so I'll run premix fuel for now. It's incredibly slow but incredibly cool 8o)
I was driving it without the cover over the carb, which I've now put on. I noticed it has a rubber gasket around it, so I'm assuming air isn't meant to get in there, so maybe it was running far too lean. I tried starting it again with the cover on and it seemed to idle better, will hopefully try it again tomorrow. Heading down to Glasgow on thursday so won't be working on it until I'm home at Christmas.
