| gs550 7k miles cafe racer build | |
carbon moto
Posts : 106 Join date : 2011-12-22 Age : 61 Location : sheffield s.yorks
| Subject: gs550 7k miles cafe racer build Sat Jan 19, 2013 9:50 am | |
| Now the xbr project is 99% finished (just got a few silly bits to do & a photo shoot at the end of next week, will post pics) We have now started another build, a 7k miles gs550 that's been in storage for most of its life.After cleaning the bike it is obvious that it is in very good condition no rust on the frame at all so its a good base for a cafe racer. [img][/img] We have quite a few gs550 5 or 6 ish so the idea is that we make this bike into a kit that can be bought to convert the 550 & 750 into a cafe racer with everything documented in the instructions, all fittings brackets etc included, this will be the test mule so to speak. We are making a completely new seat for this bike,starting with foam & covering it with body filler with lots of saning to get the shape, my lad has put something like 15 hours into this already, then we can make a mould or 2 & knock some seats out,The look im wanting is similar to the next picture (nothing fits properly as we have to de lug the frame & make a new base for the manx norton tank to fit the gs frame then it will sit properly. This one might even have a fairing | |
| Subject: Re: gs550 7k miles cafe racer build Sun Jan 20, 2013 11:33 am | |
| nice shape tank | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Sun Jan 20, 2013 11:44 am | |
| - miffa wrote:
- nice shape tank
its a manx norton 5 gal tank will be fitting a new bottom to fit the gs properly & loosing the last 4" nearest the seat the battery will fit under that part of the tank probably take it down to 4 gal then | |
| Subject: Re: gs550 7k miles cafe racer build Sun Jan 20, 2013 11:58 am | |
| is it a full tank or cover | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Sun Jan 20, 2013 1:25 pm | |
| - miffa wrote:
- is it a full tank or cover
its a tank mate but i will be sectioning a battery sized area at the back making that a cover. it will still look like the full sized tank until its taken off the bike | |
Posts : 236 Join date : 2012-01-11 Age : 57 Location : poole, dorset, england
| Subject: Re: gs550 7k miles cafe racer build Mon Jan 21, 2013 1:24 am | |
| is it a steel or glass fibre tank?
if the later, could you put your spin on our "what to line it with" debate.
by the way, already liking the lines of this one. | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Mon Jan 21, 2013 3:01 am | |
| - beekeeper wrote:
- is it a steel or glass fibre tank?
by the way, already liking the lines of this one. hi beekeeper its out of fibre glass or carbon fibre, havent decided yet We use a very high chemical resistant (yes ethanol up to 15% too) resin to make our fuel tanks, its very expensive & a pain to work with needing heat to cure it for 8-10 hours gradually getting hotter up to 80c. It works well as its what underground fuel tanks are often lined with. it took me 2 years to find this product so id rather not say what it is. | |
| Subject: Re: gs550 7k miles cafe racer build Mon Jan 21, 2013 6:54 am | |
| fully understand. pretty sure i'd say the same. | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Mon Feb 11, 2013 12:04 pm | |
| Got loads done on this & the other 2 bikes im building. This one will be known as gs550 7k miles The other gs550 will be known as gs550 #2 & a gs1000 g shaftie i hate shaft drive Will make new threads for each bike So here is what i have done on this bike. Totally stripped it to rolling chassis, cut off all brackets that are not needed ie side panel, battery box, foot peg mountings Not a lot left now. Just collected a couple of swinging arms i have had modified by my lads mate, gsxr600/750 alloy arms with twin shock mountings now welded on The seat plug & mould made & a seat has come out of the mould ,looks good with the tank will start the dry build tomorrow | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Sun Feb 17, 2013 11:07 am | |
| Had a change of plan for this bike, it wont be using the ally swinging arm.it will be all standard running gear with the standard cast ally wheels. The body work will be a Rickman tank, Rickman /Avon type fairing with one of our new design seats. Just got the foot peg hanger brackets, fairing mount bracket & the seat mounting brackts to weld on the the frame gets blasted & can then go for powder coating,just plain gloss black, hopefully next week. This is a rough idea of the look (the fairing is just sat on the fork tops) ANY SUGGESTIONS ON COLOUR as im not decided on this one yet | |
| Subject: Re: gs550 7k miles cafe racer build Sat Feb 23, 2013 2:07 am | |
| looks good m8 what screen are you going to use with your half fairing
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Sat Mar 02, 2013 11:51 am | |
| - Pud wrote:
- looks good m8 what screen are you going to use with your half fairing
We have a company that make screens for the fairings we do, smoke or clear | |
carbon moto
| just a quick update the frame is all welded up, brackets removed & smoothed off, it has now gone for blasting & powder coating (yes im not painting this frame). Will post pictures of it when it comes back. have been getting on with the engine, cleaning it up ready for painting, all side cases off it now to be polished next week | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Fri Apr 05, 2013 11:59 am | |
| Sorry for the lack of posts recently - we are extremely busy at the moment, work has been getting done but just not had a minute to post. The frame , swinging arm, brackets etc have come back from the powder coaters - a company i have not used before but a mate recommended them, i can only say wow Excellent finish done quickly at very good prices by really nice people who do ring you when its done (try them Metal magic @ barnsley s.yorks) The colour is called titanium looks like a nickle finish. The parts are coming together well, all bearings have arrived, just fitted swinging arm ones,just waiting for a big delivery of stainless fasteners then the assembly can begin. also made a new seat unit for this bike & the mould is ready to make seats more next week as it could progress quite quickly, should get the engine in during the week (hopefully) | |
| Subject: Re: gs550 7k miles cafe racer build Wed Apr 10, 2013 2:17 pm | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Wed Apr 10, 2013 2:45 pm | |
| Cheers pud. Got a bit more done on this & the other gs550. The engine is in, but still waiting for a couple of new mounting bolts to turn up along with the swinging arm nut in stainless. Polished casings now on with new stainless allen bolts. New head stock & swinging arm bearings fitted. Next job is to polish the fork legs & put new seals in them & then on with making the body work,seat,tank,fairing,mudguard & chain guard all in carbon fibre. Waiting for the wheel rims to be de chromed then to be powder coated & rebuilt. | |
| Subject: Re: gs550 7k miles cafe racer build Thu Apr 11, 2013 11:06 am | |
| luv that titty-anium colour | |
crusierlover
Posts : 3 Join date : 2013-09-24
| Subject: Re: gs550 7k miles cafe racer build Tue Sep 24, 2013 12:35 am | |
| You guys are pros.I prefer metal tanks, but your products look great. | |
carbon moto
| Subject: finished bike Mon Jun 25, 2018 2:28 pm | |
| i never got around to posting the finished pics of the bike i rode it around for a year or so then rebuilt the original motor into a big bore 673cc unit with cams and carbs to suit and gave it a make over | |
carbon moto
| Subject: Re: gs550 7k miles cafe racer build Mon Jun 25, 2018 2:30 pm | |
| a full make over followed and im now ridding around on this final(for now anyway incarnation of the gs | |
| Subject: Re: gs550 7k miles cafe racer build Fri Oct 26, 2018 3:57 pm | |
| bloody good job there matey | |
| Subject: Re: gs550 7k miles cafe racer build | |
