carb balancing EmptyFri Oct 26, 2018 3:57 pm by RussJ
carb balancing EmptyThu Jul 14, 2016 1:52 pm by TheMadman
carb balancing EmptyTue Jan 26, 2016 2:36 pm by roflhat
carb balancing EmptyTue Nov 17, 2015 4:58 am by pauliexjr
carb balancing EmptyTue Nov 17, 2015 4:23 am by Kerzo
carb balancing EmptySun Nov 15, 2015 11:31 pm by pauliexjr
carb balancing EmptySun Nov 15, 2015 3:16 pm by RussJ
carb balancing EmptySun Nov 15, 2015 3:10 pm by RussJ
carb balancing EmptySun Nov 15, 2015 3:07 pm by RussJ
 carb balancing
3 posters
stevie9183
stevie9183
PostSubject: carb balancing   carb balancing EmptyTue Feb 01, 2011 10:23 am
I fitted a open exhaust on my 790cc bonnie,im not sure if this will affect the valves ,but it does pop a bit on revving, any info on this would be great.
PostSubject: Re: carb balancing   carb balancing EmptyWed Feb 09, 2011 12:30 am
Hi Stevie, check your timing mate, backfiring through the carbs is sometimes a symptom that the valves are slightly open when the spark ignites.
stevie9183
stevie9183
PostSubject: thanks   carb balancing EmptyWed Feb 09, 2011 9:27 am
cheers i know its not firing as it should im going to get it checked out by a bike mechanic near me asap,i dont have the tech stuff to check it myself and i dont want to cause any real damage to the valves by just ignoring it.
BigMike76
BigMike76
PostSubject: Re: carb balancing   carb balancing EmptyWed Mar 16, 2011 3:48 am
The new bonnie has an air feed into the carb manifold, this is for emmisions, the reason it is popping is due to the mixture being too lean, with the open pipes, blank off the air pipe.
stevie9183
stevie9183
PostSubject: Too late   carb balancing EmptyThu Mar 17, 2011 1:09 pm
I gave up,and refitted the original exhaust,it now runs sweet as a nut,however when my mot is done in mid april i'll refit the open exhaust and try again.cheers
stevie
carb balancing
» LEAKING CARB PROBLEM ON HONDA CB400N 1978.
» Amal matchbox carb
» XS1100 project carb cleaning
» XS1100 project carb cleaning Problem
» Norton 650ss/ amal matchbox 510 carb
