Can anyone help EmptyFri Oct 26, 2018 3:57 pm by RussJ
Can anyone help EmptyThu Jul 14, 2016 1:52 pm by TheMadman
Can anyone help EmptyTue Jan 26, 2016 2:36 pm by roflhat
Can anyone help EmptyTue Nov 17, 2015 4:58 am by pauliexjr
Can anyone help EmptyTue Nov 17, 2015 4:23 am by Kerzo
Can anyone help EmptySun Nov 15, 2015 11:31 pm by pauliexjr
Can anyone help EmptySun Nov 15, 2015 3:16 pm by RussJ
Can anyone help EmptySun Nov 15, 2015 3:10 pm by RussJ
Can anyone help EmptySun Nov 15, 2015 3:07 pm by RussJ
 Can anyone help
2 posters
stevenfisher
PostSubject: Can anyone help   Can anyone help EmptyFri May 10, 2013 1:57 pm
Hi all I have been a member on here for some time I don’t post a lot but enjoy reading every ones postings I have been into bikes for a lot of year but I am having a problem with a Suzuki GP 100 that I have bought I have just got it through its MOT today but it is running like a bag of sh*t I think it is to do with the carburetor setting I have had help from a mate and it is still running like a bag of sh*t is there any one that live near Chorley that would willing to have a look Thanks Ste
hugh sym
PostSubject: Re: Can anyone help   Can anyone help EmptyFri May 10, 2013 4:12 pm
Hi fella, what have you tried,,,, Take a look at the spark plug, is it the right one for the bike, is it gapped correct. Plug lead and cap, are they good, any cracks or signs of arcing, change them. I take it your on points? have they clean contact surfaces (un pitted) if they are pitted change them AND the condensor. Timing? is that correct? adjust by moving the stator plate if needed, you will need a strobe light for this.
Carb problems, air filter?, missing, choked up, blockage in inlet, a rag under seat if a common one. Carb, is it clean, like really clean?, if the bike has been standing petrol varnish builds up and can choke up air ways the emulsifire (check spelling) tube. Float hight set correct, needle clip sitting in centre groove, air bleed screw set somewhere near, wind it all the way in and then wind it 1 and a half turns out.
You will need high pressure air (compresser) to blow all air ways through. Carb removed check rotor valve plate for scoring and damage, replace if needed. Air leaks, check all gasket / O ring seals for condition replace if suspect.
Oil as in two stroke, use quality stuff, you running mixed or posi lube, make sure your oil ratio is correct, too little oil motor runs hot and to much oil motor also runs hot.... Sorry Steve, nothing in any order, just do everything and see how you go, are you a heavy drinker, smoker or drug user,,,
stevenfisher
PostSubject: Re: Can anyone help   Can anyone help EmptyFri May 10, 2013 10:30 pm
Thanks for all that as yet I will say no to the drugs but by the end of it you never know I have tried a lot of what you have said the plug looks good when I got the bike they were mixing the oil in to the tank due to the bike didn’t have a two stock oil pump I have put a new one on the bike one minute the bike runs ok it ticks over ok the only thing I have noticed is a build-up of oil in the exhaust I am going to try to take the baffles out of the exhaust today to see if there is a build-up dirt that could be blocking it but the person that as had it before me as took an hammer to it
Can anyone help
