1976 CB 400f Restore project (wiring)  EmptyFri Oct 26, 2018 3:57 pm by RussJ
1976 CB 400f Restore project (wiring)  EmptyThu Jul 14, 2016 1:52 pm by TheMadman
1976 CB 400f Restore project (wiring)  EmptyTue Jan 26, 2016 2:36 pm by roflhat
1976 CB 400f Restore project (wiring)  EmptyTue Nov 17, 2015 4:58 am by pauliexjr
1976 CB 400f Restore project (wiring)  EmptyTue Nov 17, 2015 4:23 am by Kerzo
1976 CB 400f Restore project (wiring)  EmptySun Nov 15, 2015 11:31 pm by pauliexjr
1976 CB 400f Restore project (wiring)  EmptySun Nov 15, 2015 3:16 pm by RussJ
1976 CB 400f Restore project (wiring)  EmptySun Nov 15, 2015 3:10 pm by RussJ
1976 CB 400f Restore project (wiring)  EmptySun Nov 15, 2015 3:07 pm by RussJ
Share
cafesoldier
PostSubject: 1976 CB 400f Restore project (wiring)    1976 CB 400f Restore project (wiring)  EmptyMon Mar 26, 2012 8:03 pm
Hey everyone gotta write this first one quick. So I bought my first bike a lil while ago a 1976 cb400f.Awesome bike but someone started the cafe build on it and now I gotta finish it. So my biggest problem so far is my wiring..its all messed up. I ordered new hand controls from dime city, they should be here this week. I just want some advice on replacing and rewiring this bike. As of now when I apply battery power the stater starts trying to crank the engine. Is that normal?
PostSubject: Re: 1976 CB 400f Restore project (wiring)    1976 CB 400f Restore project (wiring)  EmptyMon Mar 26, 2012 9:41 pm
First off welcome aboard and good luck with your project, look forward to seeing some pictures as the build progresses.
As for your wiring issue, no, you shouldn't get anything happen when you apply the power, nothing should switch on or start until you turn on the ignition switch and activate the appropriate control i.e. light switch, horn, indicator or starter button. If it's trying to crank from the go-get you have an open or short circuit. There is obviously a live feed directly to the starter solonoid that is by-passing the ignition switch and starter button.
Try hooking up with these guys http://www.sohc.co.uk they are very helpful, knowledgable people, they have a forum specifically for the CB350/400 and somrone may be able to throw some light on your problem or even send you a copy of the wiring diagram.
Cheers,
Pau
PostSubject: Re: 1976 CB 400f Restore project (wiring)    1976 CB 400f Restore project (wiring)  EmptyTue Mar 27, 2012 2:09 am
hi cafesoldier
dont try and run the bike as is you will burn your starter motor out it will be constantly spinning when its running
if your bike turns over without pressing the starter ,first check the wiring to the back of the ignition then check the wiring to the solenoid if either as its wires at the wrong pole that will happen ,if it only happens with the key switch in the on postion then its proberly a dodgy starter button
has the loom been cut into?? if so theres new looms avialable at 40 quid or just make your own that way you dont have to have all the surplus crap
Seller assumes all responsibility for this listing.Item number: 130665512603
this will work for your bike or use it just to check that yours is wired correctly
1976 CB 400f Restore project (wiring)  Ebe35d7e-4315-4baa-adcf-c76d8fa79b80
PostSubject: Re: 1976 CB 400f Restore project (wiring)    1976 CB 400f Restore project (wiring)  EmptyTue Mar 27, 2012 5:43 am
Miffa, that is bloody brilliant! Do you have that as an image you could mail me? I'd like to print it off and add it to the Haynes manual for the 750 Very Happy
PostSubject: Re: 1976 CB 400f Restore project (wiring)    1976 CB 400f Restore project (wiring)  EmptyTue Mar 27, 2012 6:28 am
yes mate PM me your email and i will send it to you
» kawasaki 220 Bayou
» Kawasaki mule 2510 Corbett hunting buggy project
» Project Peenemünde!
» Project 45 For Sale
» Cheap go kart project
